NI TestStand
where is modelsupport.dll
(4,212 Views)
It should be in the following folder:
\Components\NI\Models\TestStandModel
Azucena Perez
(4,212 Views)
The modelsupport2.dll is in the TestStandModel directory, but not modelsupport.dll. The functions I need were in the original modelsupport.dll file packaged with TestStand 1.0.2. The functions needed are UIMessage_Event calls.
(4,212 Views)
If you are using TestStand 2.0 then you need to use modelsupport2.dll. The UIMessage functions are still there.
If you are using the User folders, then you will have to copy the new NI folders across to the User folders. Making sure you have backed up first.
Ray.
Regards
Ray Farmer
(4,212 Views)
I have looked in this dll, and I don't see the function we use called PostUIMessage.
(4,212 Views)
NI have removed a load of wrapper functions from the modelsupport.dll. The API function PostUIMessage is still available (Thread.PostUIMessage) so it looks like you will have to use the API function or the new PostUIMessageEx function.
Regards
Ray.
Regards
Ray Farmer
(4,212 Views)
