NI TestStand
Why is delocalize replacing commas with period when option 4 is used?
Only before numbers
I am using TS2012
(2,449 Views)
This is from the TestStand help: The method replaces the localized decimal point characters that represent decimal points in the expression with the period character. If the localized decimal point character is the comma character, the method also replaces semicolons that represent argument separators or expression separators with commas. The method does not change characters inside string constants.
http://zone.ni.com/reference/en-XX/help/370052K-01/tsapiref/reftopics/engine_delocalizeexpression_m/
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,425 Views)
But there is no decimal point in "a,b,5" and it still replaces the , before the number.
(2,418 Views)
So technically your expression is a,b,5  Try doing this: "\"a,b,5\"" and see if that helps.
My guess is that it thinks your machine is localized to some European way of using the , instead of the . and it is trying to swap it to a . so it is localized to TestStand.
jigg
CTA, CLA
testeract.com
(2,403 Views)
