NI TestStand
what is error 39 on GPIB-ENET???windows2000/nt 1.2
I have a test stand and I am running windows 2000 version 1.20 and my GPIB-ENET IEEE488 is giving me an error 39. What is this error and how can I fix it?
(3,678 Views)
Hi there,
I have a few questions regarding your error.  When does this error occur? Does occur when you try to identify the device on the network? Does it occur when you try to run a command in LabVIEW or your code?  Also, do you have any more specifics regarding the error code, any additional numbers, any specific resources returning the code?  Could you post a screen shot of the error code?
In your post you mention version 1.20, is this the version of the NI-488.2 drivers?  If so, you may want to update your GPIB drivers, you can download the latest drivers here.
Ted
Ted H
Applications Engineering
(3,666 Views)
The error pops up right when we turn the GPIB on and I can not send a picture.
(3,640 Views)
Can you describe the error in any more detail?  Is 39 the only number associated with this error? Have you tried using the GPIB-ENET device with other systems?  Is this error unique to this system, or does it occur with other systems as well?  Any other detail you can provide would really help.
Thanks!
Ted
Ted H
(3,635 Views)
A few more questions.  What is throwing this error code?  Is the GPIB device sending it (through a series of LED flashes?), or is Measurement and Automation Explorer or LabVIEW or Windows throwing the error?  More information would really help.  Thanks!
Ted
Ted H
(3,613 Views)
Sorry for digging up this thread, but I am also facing an old GPIB-ENET device throwing 39 error code over its READY LED.
What those it means?
(2,559 Views)
