NI TestStand
Why is my NI TestStand having "TestStand Debug Options Warning" everytime I close it?
hi mathis,
i don't see "TestStandModels" folder on both of these paths,
C:\Users\Public\Documents\National Instruments\TestStand 2014 (64-bit)\Components\Models
C:\Users\Public\Documents\National Instruments\TestStand 2014 (32-bit)\Components\Models
and for both paths, i only have these folders in "Models" folder
But i can see "TestStandModels" folder on both of these paths,
C:\Program Files\National Instruments\TestStand 2014\Components\Models\TestStandModels
C:\Program Files (x86)\National Instruments\TestStand 2014\Components\Models\TestStandModels
am i having the correct file path for "TestStandModels" folder?
thanks,
val87
Message 11 of 24
(2,963 Views)
It actually seems that something regarding the Import/Export dialogue/binaries is corrupted.
I'm surprised the re-install didn't fix things. When you "re-installed" Teststand, did you un-install it first (re-installing a piece of software which is already installed is simply doing nothing ... the installation will be skipped).
Do you have an active SSP? This sounds like a case for NI support.
It doesn't seem that you are doing anything wrong ... it simply isn't working the way that you would exptect to.
Sorry that we couldn't be of better help
Best Regards
Mathis
Message 12 of 24
(2,951 Views)
hi mathis,
what i did is un-installing the Developer Suite package including TestStand and re-installing it all over again. but still, the issue was there.
i also did un-installing only the teststand and re-installing it, still the issue is there.
thanks for the help though, appreciate it.
val87
Message 13 of 24
(2,938 Views)
Val,
what is your station model?
Do you have custom report plugins which might have messed things up?
Do you have custom users or are you logged in as "administrator"?
What happens if you select the Import/Export tool? Is there some error popup?
Please note that un-install does NOT remove custom settings (<users>\Public\Documents\National Instruments\TestStand<...>). So if you have items in there messing up the system, a re-install will NOT solve the issue.
Norbert
EDIT: You are using the NI Sequence Editor? Or is it a custom editor interface?
Norbert
Expert: Geometry
Message 14 of 24
(2,926 Views)
hi norbert,
i am using SequentialMode Sequence and logged in as administrator.
i also used the ni sequence editor. the issue also appears when using operator interface.
when i select import/export properties, nothing happens..no error and no dialog box appear.
thanks,
val87
Message 15 of 24
(2,913 Views)
Val,
the Import/Export tool is "controlled" by the ImportExport.seq you should find in <Program Files>\National Instruments\TestStand <version>\Components\Tools directory.
Verify that this sequence file has the correct content (compare 32bits and 64bits).
The C/C++ DLL call placed in there actually calls into the dialog. I assume that the incorrect working version points to the false DLL version. Therefore, the DLL cannot be loaded.
Norbert
Norbert
Expert: Geometry
Message 16 of 24
(2,906 Views)
hi norbert,
i can find the ImportExport.seq sequence file in both folder paths,
C:\Program Files\National Instruments\TestStand 2014\Components\Tools
C:\Program Files (x86)\National Instruments\TestStand 2014\Components\Tools
I am not sure how to verify your idea of this one,
"The C/C++ DLL call placed in there actually calls into the dialog. I assume that the incorrect working version points to the false DLL version. Therefore, the DLL cannot be loaded."
in my case, am i having incorrect version that points to the false DLL version?
thanks,
val87
Message 17 of 24
(2,903 Views)
Val,
in your initial post, you told us that 64bit is working as expected, 32bit fails.
So my assumption is that in the 32bit version of the ImportExport.seq, the call points to the 64bit version of the limitloader.dll.
If i am correct, it is most likely that you have messed up search directory configurations in your 32bit version of TS.
Norbert
Norbert
Expert: Geometry
Message 18 of 24
(2,901 Views)
norbert,
that might be the cause since i am still new to TS so maybe i messed up something in my 32bit.
would you know on how to fix this? i have attached the ImportExport.seq sequence file from this path,
this is for your reference.
thanks,
val
Message 19 of 24
(2,899 Views)
val,
i didn't look into your sequence file as i think it wont help in our discussion.
You have to make sure that the actual path to the module is correct. TS shows you the path it uses as an indicator in the step settings:
Verify that the path is correct (x86 vs "none"). Also make sure that the DLL is located there.
Norbert
Norbert
Expert: Geometry
Message 20 of 24
(2,886 Views)
