NI TestStand
Why is my NI TestStand having "TestStand Debug Options Warning" everytime I close it?
hi norbert,
the limitloader.dll path for both x86 and "none" are correct (same as what you've shown)
but i've found a difference in number of files content in each folder.
thanks,
val87
Message 21 of 24
(2,175 Views)
val,
do other popup dialogs work with your TS2014 32bit? I refer mainly to Station Config, Result Processing and the other tools available in the Tool menu.
Or is Property Import/Export the only affected tool?
Also please make sure that there is no ImportExport.seq in the <user> directory of TS (e.g. C:\Users\Public\Documents\National Instruments\TestStand 2014 (32-bit)\Components\Tools).
Norbert
Norbert
Expert: Geometry
Message 22 of 24
(2,173 Views)
norbert,
only Import/Export Properties dialog box is affected,. i can launch other pop-up box under Configure and Tools.
i have an empty folder for both paths,
C:\Users\Public\Documents\National Instruments\TestStand 2014 (64-bit)\Components\Tools
thanks,
val
Message 23 of 24
(2,170 Views)
val,
what strikes me a little is that both DLLs have the exact same date of "last modified" in your screenshot. So it is possible that due to a mess up the DLL got copied from one location to the other.
Good point is that the 32bit version includes the source files for the DLL. So if you have LabWindows/CVI available, you could rebuild the DLL for 32bits.
Question: Do you have another PC where you can fresh install 32bit TS for verification/support purpose?
Goal is to verify that your 32bit installer works correctly on the fresh system. If it does, we can start copying files (e.g. the DLL) from that system to the affected one.
Norbert
Norbert
Expert: Geometry
Message 24 of 24
(2,162 Views)
