NI TestStand
Write UUT Serial Number scanned at beginning of test sequence to a text file
Is there a way to get the Serial Number string / value that every default test stand sequence scans and store it to a text file? What variable / parameter is that scanned value even stored in?
I tried using a Call Executable function like in the screenshot attached. But whenever I go to that output file, it is blank. Am I calling the wrong parameter?
Message 1 of 9
(1,611 Views)
Think you are missing the redirection of the echo command to the file
echo somtehing > test.txt
Message 2 of 9
(1,532 Views)
Do you happen to know if that parameter of "Runstate.Root.Locals.UUT.SerialNumber" is the correct parameter to pull this data from? I fixed the echo command by adding > and I even tried >> to just have it overwrite whatever is in the test.txt file. But nothing is still written to that file.
Message 3 of 9
(1,519 Views)
Does the Write to file operation work with a constant string?
RunState.Root.Locals.UUT.SerialNumber is correct, yet it is only existing when the process model is run
Message 4 of 9
(1,515 Views)
I tried to just put in "hello" as a string in that command and nothing got written to the test.txt file.
Message 5 of 9
(1,504 Views)
I am confirming this behaviour ☹️
I could get a file created when redirecting STDOUT to the file. Yet the file seems to get overwritten each time, so no appending
Message 6 of 9
(1,500 Views)
This attached picture allowed me to print the string "test" into the test.txt file I had on my desktop.
Now just need to get this to work on actually pulling the UUT serial number during runtime to get that recorded into a .txt file.
Message 7 of 9
(1,492 Views)
I had tried the \\ as well but failed, seems I still made another mistake
Suggesting another solution: have you considered using a data stream step type to write in a kind of nicely formatted csv File?
Message 8 of 9
(1,475 Views)
I will have to try this. My concern is that I cannot pull the UUT serial number into any file (whether .txt like I am attempting now, or via a .csv data stream) as I cannot find the Runtime variable that it gets stored to. But will need to at least try to see what I get.
Message 9 of 9
(1,439 Views)
