NI TestStand
facing errors in the test sequence
I created one test sequence for my project ,the sequence working properly but while I am analyzing in the sequence analyzer it is showing some errors but here main sequence working fine then what is the problem .
(878 Views)
Depends…..
guess you will get an answer if you specify what you’re seeing there. Screenshot might help 😉
(842 Views)
