NI TestStand
Wrong Wait() step execution time
I installed latest TestStand (v4.2.1) on a Quad Core PC (Intel Core2 Quad CPU, Q9400 @ 2.66GHz), but I am noticing the same problem. The computer is up to date in terms of Windows update as well.
I found some topics on the web about the pmtimer issue. But, before I make the change in boot.ini on the new computer, I wanted to check if:
1) Intel processors have the same problem?
2) Can changing to PM Timer have any side effects on performance?
http://kb.mozillazine.org/Timeout_on_dual_core
http://blogs.msdn.com/tvoellm/archive/2008/06/05/negative-ping-times-in-windows-vm-s-whats-up.aspx
Are future releases of TestStand planned to workaround this issue?
Thanks!
Message 11 of 15
(2,037 Views)
Am I right to assume that TestStand 2012 and 2014 also use the PerformanceTimer API?
I am getting interesting effects on different machines that the execution time of a Wait(0.01) is anwyhere between 10.5 and 18ms, relatively stable on each machine, but different between machines.
I am measuring the time by using a logging library which also logs the values of the PerformanceTimer ...
Best regards
Peter
Message 12 of 15
(1,634 Views)
The wait step does not use QueryPerformanceCounter when waiting on a time interval, and thus is limited by the system clock's resolution. TestStand does use QueryPerformanceCounter in other places though, such as Engine.SecondsSinceStart and related APIs.
Hope this helps,
-Doug
Message 13 of 15
(1,630 Views)
Actually, in looking at things more carefully, the wait step does use QueryPerformanceCounter in that it calls Engine.SecondsExecuting and other engine APIs to determine if the timeout has expired since it takes things into account like not counting the time the execution was paused at a breakpoint. However, the wait step also calls Sleep() to give up CPU time and the Sleep() api is subject to the resolution of the system clock.
Hope this helps clarify things,
-Doug
Message 14 of 15
(1,624 Views)
Yes, thank you, that clarifies it.
I originally assumed the Wait step to use Sleep() for giving up CPU time and then was a little confused as waiting for a PerformanceTimer value should both be more accurate and a lot more busy.
Peter
Message 15 of 15
(1,621 Views)
