a problem was encountered with one of the files in TestStand\AdapterSupport\LabVIEW directory
When looking at the module for a LabVIEW VI being called from TestStand, I get the following message:
A problem was encountered with one of the files in TestStand\AdapterSupport\LabVIEW directory.  Please reinstall it or repair it.
I made the mistake of cleaning up C: in my computer.  Cleaning C:\National Instruments Downloads
Why would someone put bits of applications or modules, etc in such a directory?
I am not too crazy about restoring 11GB back into that folder.  That's just insane!
Has anyone encountered this before?  Any "easy" solutions? apart from re-installing TS...
Side note:  I did not touch anything in the \Program Files|National Instruments\TestStand\AdapterSupport\LabVIEW
(3,262 Views)
Accepted by Ray.R
What version of LabVIEW and TestStand are you using?
In 2012 TestStand that directory is mapped to:
C:\Documents and Settings\All Users\Documents\National Instruments\TestStand 2012\AdapterSupport\LabVIEW
Did you try mass compiling the VIs in this folder?
I have had to create a new 'TestStand - Default Values XX.llb' file where XX is the latest version of LabVIEW you are using, but I have not seen that message before.
Good luck,
PH
(3,251 Views)
Thanks PH,
I also had that.  Fixed it.
I will not remove the ones in the NI downloads folder.
I will eventually need to remap everything to the appropriate drive.
I partition the drives into:
C:\     Windows and associated folders.  Mostly OS stuff
E:\     Applications (this is where it will end up)
F:\     Files
G:\    Storage
H:\    Backups
I try to do what I normally implement in Linux.  I hate sharing the OS with everything else.
Cheers,
RayR
(3,242 Views)
