NI TestStand
activate or skip "Record Results" and "Step Failure Cause Sequence Failure" for all steps of a step type
Hello all,
I am using teststand 3.1
Is it possible to skip or activate ´"Record Results" and "Step Failure Cause Sequence Failure" for all steps of a step type.
It is very much work to do this for all steps, because I have hundred of steps
regards
samuel
(3,627 Views)
To set a step to skip you have to set the TS.Mode = "skip" eg RunState.Sequence.Main[0].TS.Mode = "skip" would set the first step in Main of the active Sequence.
Likewise with the Record Results, would be TS.NoResult = True for not too record the step result.
and
TS.StepFCSeqF = True would cause the sequence to fail if the step failed.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,613 Views)
Thank You Ray,
but this method only handles one step. I want to skip all steps of a step type for example all Statement steps.
How is this possible?
regards samuel
(3,600 Views)
Do you want to change the static version or the runtime version of the sequence file?
Ray.
Regards
Ray Farmer
(3,597 Views)
The static version
samuel
(3,594 Views)
hi,
here is an example that will change the TS.NoResult. You just have to change this area of the sequence to suit your needs
I haven't added any fancy stuff, such as adding a filedialog to get the seq file to change, you will find the various variables in the Locals.
Hope it helps
There is a version for 3.1 and 3.5.
Regards
Ray Farmer
Regards
Ray Farmer
(3,583 Views)
