06-04-2006 06:21 AM
06-05-2006 03:05 PM
06-06-2006 05:16 AM
I am talking about reports in teststand, i mean table, it simple html table in the report. So i looking for ability to create tables, more then just one table with ResultsArray values
06-07-2006
12:57 PM
- last edited on
11-06-2025
01:41 PM
by
Content Cleaner
Hello pdobkes,
If I understand your question correctly, you are asking how to add new html tables to the TestStand report. Normally this would be done through the TestStand process model. This is where the report is actually generated. I have listed some links below that explain how TestStand reporting works, and also a document that explains how to add more results to the result array which will then include them in the report.
Report Generation Explained
UnderStanding and Modifying Result Collection
