NI TestStand
batch scheduling of tests
I was interested in learning how one could batch or schedule tests to be executed ?
(3,002 Views)
Canwebe,
I'm not extremely certain what you're looking for here. Assuming that you want to schedule an entire sequence to run at a certain time, their is no built-in feature for doing so. However, you could easily create a LV VI that would open the sequence file and execute it. This VI could be made into an executable and then scheduled using XP's Schedule Tasks function. If you are trying to time the actual tests within the sequence, there are multiple ways to do so. Also, if you are trying to use the Batch process model to do test multiple items simultanously, there are multiple synchronyzation steps to allow for both serial and parallel testing of multiple UUTs. I hope this helps, but if you have any other questions, please feel free to repost. Thanks.
Ada
m B.
(3,002 Views)
