NI TestStand
How to abort an executing step?
Using TS 3.0, I call CVI DLL steps. I want to be able to terminate(exit) an executing step either from TS or within an error handler within the DLL. I want the sequence to give the operator a choice to resume at the next step or Terminate with cleanup. The DLL steps are not structured to branch to the normal DLL function return(perhaps there's such a way?).
(3,192 Views)
Hello Bob Balch,
The question that you have posted is not trivial to implement. However, there are ways to accomplish that task. I believe that it will be better to discuss the different programming ideas I have for you off-line, so I will be sending you a direct email in the very near future with the ideas that I have for you.
Kevin Leonard
(3,191 Views)
