NI TestStand
Setup failure not recorded in Execution.ResultStatus
If a step fails during the Setup section of my sequence, the result visible in a VB.NET event handler is "Passed", rather than the expected "Failed" or "Error".
Private Sub ExecutionTwoFinished(ByVal sender As Object, ByVal e As NationalInstruments.TestStand.Interop.UI.Ax._ExecutionViewMgrEvents_EndExecutionEvent) Handles axExecutionViewMgrTwo.EndExecution
If e.exec.ResultStatus = StepProperties.ResultStatus_Passed Then
End If
End Sub
I have "Step Failure Causes Sequence Failure" selected.
Is there a setting which I am missing to cause the failure to be reported correctly?
Thanks!
(3,102 Views)
Hello PMichaelson,
I tried to replicate the issue that you are experiencing, but unfortunately I was not able to see the same behavior that you are seeing. When I ran a TestStand 3.1 sequence, which had a step that failed in the setup code group, the variable e.exec.ResultStatus from the function you listed in your post did return �Failed.� As long as your sequence is set to run the Setup and Cleanup code groups, I am not aware of any other settings in TestStand to force this behavior. If you are still having problems with this issue, you can create a small example which demonstrates this behavior, and feel free to attach it to this page. I will then see if I can replicate it on my end.
Kevin Leonard
(3,102 Views)
