NI TestStand
find unused teststand locals, how?
Is there a way to search a sequence for locals that are no longer referenced? During development I created quite a few locals that now I no longer need. I like an easy way to find them so that I can delete them. I'm using TestStand 2.0
(2,984 Views)
Kevin -
In TestStand 2.0 the only way to search a sequence file is to search the file using a text editor and then try to figure out what the text in the file is referencing.
In TestStand 3.x, we have added find/replace feature in the sequence editor. This feature searches a single file or multiple files easily and you can limit the search in many ways, so it would be able to tell you. It also has a goto location feature which brings you to the dialog where the item is being referenced.
Scott Richardson (NI)
Scott Richardson
https://testeract.com
(2,984 Views)
