breakpoint bit
Is there in Teststand Context a bit that shows if the breaktpoint was set?
(5,080 Views)
I'm not sure I follow what you are asking.  Do you want to see if they breakpoint is enabled?  Or if the condition for it was met?  Or if it even exists?
jigg
CTA, CLA
testeract.com
(5,073 Views)
I want to see if it was enabled.
(5,059 Views)
Put this in a statement step :
Locals.bool=RunState.Engine.StationOptions.BreakpointsEnabled
This returns True for enabled.
Ravi
(5,045 Views)
Thanks SunRS, but that wasn't my purpose. I want to see if the breakpoint is set or was set in step(s) before.
(5,023 Views)
Accepted by Rokot
See the API help for: Step.GetBreakSettings()
Hope this helps,
-Doug
(5,016 Views)
