NI TestStand
breakpoint bit
Is there in Teststand Context a bit that shows if the breaktpoint was set?
(4,995 Views)
I'm not sure I follow what you are asking.  Do you want to see if they breakpoint is enabled?  Or if the condition for it was met?  Or if it even exists?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,988 Views)
I want to see if it was enabled.
(4,974 Views)
Put this in a statement step :
Locals.bool=RunState.Engine.StationOptions.BreakpointsEnabled
This returns True for enabled.
Ravi
(4,960 Views)
Thanks SunRS, but that wasn't my purpose. I want to see if the breakpoint is set or was set in step(s) before.
(4,938 Views)
Accepted by topic author Rokot
See the API help for: Step.GetBreakSettings()
Hope this helps,
-Doug
(4,931 Views)
