can we view line numbers next to each step in sequence file ?
    I have a sequence file having 600 steps. I would like to know is there any option in test stand to set line number for each step in sequence editor so that it will be helpful for review.
Example:
1 Action1
2 Action2
600 Action600
krishna
(5,143 Views)
Hey Krishna,
This currently is not possible to my knowledge.  If you want to suggest it then you can go to NI's product suggestion page: http://digital.ni.com/applications/psc.nsf/default?OpenForm
If you want to print your sequence then use the documentation tool: Tools>>Sequence File Documentation.  This creates a more readable version of your sequence.
You could rename all your steps.......but then when you add a new step you will have to rename all the steps after the added one again.
jigg
CTA, CLA
testeract.com
(5,141 Views)
Accepted by topic author krishna_ak
Krishna,
If you just want to know the index of a step, this information is displayed at the bottom of the sequence editor in the status bar.  It shows you how many steps there are in the sequence, how many you have selected, and the index(es) of the selected step(s).
It is also possible to display this information in the steps view as a column if you are willing to create a new column.  Follow the instructions in this KB to see how to create a new column:Changing Columns Properties of the TestStand Sequence Editor Execution View Window.
One of the types of colums is Index. Simply set your column to that type and you will see step indexes as shown below.
Message Edited by Josh W. on 07-01-2009 01:50 PM
Message Edited by Josh W. on 07-01-2009 01:53 PM
Josh W.
Certified TestStand Architect
Formerly blue
(5,137 Views)
Thanks josh.
Krishna.
(5,131 Views)
