NI TestStand
centralized user management
Is it possible to manage TS users from a centralized poin (using a network drive)?
I have a couple of machines running TestStand and would like to manage the users able to login to those machines. I know I can define the location of the config directory for TestStand, but then I get all other ini files like StationGlobals, etc. into the same dir, so it's not a solution.
Is there a way to tell TestStand to search just for the users.ini file in a location different to the standard Cfg directory?
(3,987 Views)
Accepted by paicolman
Sure, edit the User Manager tab of the Station Options.  Uncheck "Use Default" and browse to the user.ini file you would like to use.
Message Edited by paulmw on 11-18-2009 10:13 AM
Message Edited by paulmw on 11-18-2009 10:14 AM
(3,971 Views)
Thanks! ...Another case of RTFM.
(3,942 Views)
How do I do this using the API? I've been looking and looking and can't find anything..
(3,370 Views)
Engine.StationOptions.UserFilePath = "<YourPathHere>"
UserFilePath Property
Syntax
Data Type
String
Purpose
Specifies the location of the current user manager file.
Remarks
Pass an empty path to this property to instruct TestStand to use the default user manager file.
A change to this property does not take effect until you restart the engine.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,365 Views)
