NI TestStand
changing step properties en masse
Hi All,
Is it possible to edit the same property of a number of different steps simultaneously instead of having to edit each step's properties individually resulting in many repetitive actions? For example, if I wanted to turn off the reporting in a selection of steps in a sequence.
regards,
Mike V
(3,124 Views)
Currently this is not an option in TestStand.  There is a product suggestion submitted for this feature and R&D is taking it into consideration.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,113 Views)
One way you can do this is to do a find and replace on a sequence file (make sure you have Hidden Properties Visible).  TestStand stores all of this information in a property, and you could selectively change the value to be something else.
For your example, you would:
1) Select Edit >> Find
2)  Search for "TS.NoResult".
3)  Select the steps you wish to change the Result Collection Option to.
4)  Type either "True" or "False" in the "Replace With" text.
5)  Click "Replace Value".
Hope this helps!
Allen P.
NI
(3,107 Views)
