04-04-2008 03:51 AM
04-04-2008 04:41 AM
Hi Neil,
This doesn't actually sound like a TestStand related query. Infact not sure where you are aiming this at.
If it not TestStand then I suggest you repost in the correct forum.
If it is TestStand, the what version are you using, which code language, maybe post a small example to hightlight your problem
Regards
Ray Farmer
04-04-2008 04:44 AM
Ahh, yes you are correct. It is a signal express question. I didn't see that... in fact I did select the Signal Express forum but something must have gone wrong.
How can I move this to the signal express section?
Thanks for your help.
04-04-2008 05:38 AM
Thanks Ok, Its a common problem posting to the wrong forums. You just have to recheck that your Forum selection is still correct before Posting your question.
Regards
Ray Farmer
