NI TestStand
channel names in ascii file
Hi there,
This maybe a rookie question but I am a relative rookie to this software, and I hope it has an easy fix!
Background:
Take a load of analogue inputs from a DAQ device into Signal Express, first thing that hits me is that unlike labVIEW you cannot right click in the channel configuration window and change the name from say... Dev2_ai0 to Air Pressure? I feel that if this was possible then I would overcome my problem? anyway I can't so onwards...
I goto the DAQmx Acquire window on the top left and can right click and rename the channel, which is great... however this does not translate to the logged data as I get the ai0 channel names across the top of the columns and not the names that I have put in.
Is there anyway of getting data like the attached snippet?
Many thanks for your help in advance.
Neil Barker, Redbull Technology.
(3,367 Views)
Hi Neil,
This doesn't actually sound like a TestStand related query. Infact not sure where you are aiming this at.
If it not TestStand then I suggest you repost in the correct forum.
If it is TestStand, the  what version are you using, which code language, maybe post a small example to hightlight your problem
Regards
Ray Farmer
Regards
Ray Farmer
(3,358 Views)
Ahh, yes you are correct. It is a signal express question. I didn't see that... in fact I did select the Signal Express forum but something must have gone wrong.
How can I move this to the signal express section?
Thanks for your help.
(3,356 Views)
Thanks Ok, Its a common problem posting to the wrong forums. You just have to recheck that your Forum selection is still correct before Posting your question.
Regards
Ray Farmer
Regards
Ray Farmer
(3,344 Views)
