NI TestStand
copying seqs/teststeps between seq-files
While copying seqs/teststeps between seq-files,
loading options are changed without notification.
They were switched from "load dynamically" to
"pre-load...". (Version was 1.0.3)
(3,041 Views)
Unfortunately, I was unable to reproduce your problem. I tested with Windows 2000 and Windows XP. I tried TestStand 1.0.3, 2.0 and 2.0.1 and I never got the behavior you noticed.
If you didn't notice this behavior with any other computer, then maybe there is something wrong with this particular computer.
What is the OS you are using?
Roberto Piacentini
www.ni.com/support
(3,041 Views)
