NI TestStand
corresponding object file does not exist
Using TestStand, I created a deployment - it's supposed to use the workspace file I created that contains only one sequence file. When I deploy on the target, and I open the sequence file, it says "The corresponding object file for the source module Lmbsu_Setup.c does not exist. Would you like CVI to create it for you?"
What do I need to include in my TestStand workspace file, sequence, or CVI project that will satisfy TestStand at the target end.
(3,278 Views)
Hello mrbean:
It seems that it wasn't able find the file "Lmbsu_Setup.c". You might want to include it with your workspace file.
I hope this helps.
(3,262 Views)
