NI TestStand
creating locks between executions
My sequence launches a new execution. If lock is required to be shared between the executing sequence and new execution (that the current sequence launches) should the lock name be created with asterisk (*) as the first character in the name?
Does new execution runs in different processes?
TIA.
CLD
(3,190 Views)
Accepted by lvrat
No, new executions run in the same process. The '*' is only needed if you are running multiple applications that share locks, for example, multiple instances of the sequence editor or user-interfaces.
Hope this helps,
-Doug
(3,173 Views)
