NI TestStand
creating locks between executions
My sequence launches a new execution. If lock is required to be shared between the executing sequence and new execution (that the current sequence launches) should the lock name be created with asterisk (*) as the first character in the name?
Does new execution runs in different processes?
TIA.
CLD
(3,291 Views)
Accepted by topic author lvrat
No, new executions run in the same process. The '*' is only needed if you are running multiple applications that share locks, for example, multiple instances of the sequence editor or user-interfaces.
Hope this helps,
-Doug
(3,274 Views)
