creating parallel thread
Hi guys,
I want to create a parallel thread with one .VI in it. How can I create one and how to set priority and time interval. This .VI checks if a device is alwayz present. I want this thread to start after a certain step.
(3,346 Views)
Accepted by JoVMo
You can use a Sequence Call (put the VI inside that)  and configure the Sequence call  to run in a separate thread (Module - Execution Option - Use New Thread)
AshwiN,
(3,343 Views)
ok, thank you....
(3,339 Views)
