NI TestStand
custom step properties window size
I am learning to create custom Steps in Teststand. There appears to be something wrong with the properties box, it looks like there are options just off the window which I can't access, just below 'Designate an adapter'. I think this must include the 'OK' button, as it doesn't save the parameters which I set.  Does anyone know how to resize the window to fit?
   Ian
(4,163 Views)
Hi Ian,
Would it be possible for you to attach a screenshot, labelling exactly what you mean?? Also, which version of TestStand are you using?
Kind regards,
TomS
(4,143 Views)
Teststand version is.0.274. Unfortunately I can't get a screenshot as rebooting the PC fixed the problem for the time being. Thanks all the same
(4,130 Views)
