NI TestStand
database error
I am seeing an error when I try to run a seq file.  When I hover over the large ! it says, “The type library information for “TestStand Database Options” was not found.  Ensure that the server is registered on the computer”.  I went to Database Options and see THIS.  Any thoughts on what it’s looking for?
(3,117 Views)
Hi mrbean,
What TestStand Version are you using? And the OS?
(3,087 Views)
Using windows 10 and teststand 2016
(3,084 Views)
Do you have the database option enabled on result processing?
(3,076 Views)
Hey,
Are you seeing error -18351 like the following KB is showing - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019L0JSAU
(3,069 Views)
