09-01-2010 01:51 PM
From the MainSequence, I can make the call shown (just trying to see if "M38432002" is found in the name of the sequence file)
Find(ThisContext.SelectedFile.Path,"M38432002",0,True,False))==-1
But if I try this from PreUUT, it doesn't know what 'ThisContext' is. Is there a way to determine the name of the sequence file when we're in the PreUUT sequence?
09-01-2010 04:14 PM
RunState.ProcessModelClient.Path
PH
09-01-2010 04:27 PM
It needed 'Caller' just before ProcessModelClient, then it worked. THanks so much.
RunState.Caller.ProcessModelClient.Path
09-02-2010 05:44 AM
