NI TestStand
determining calling sequence file
From the MainSequence, I can make the call shown (just trying to see if "M38432002" is found in the name of the sequence file)
Find(ThisContext.SelectedFile.Path,"M38432002",0,True,False))==-1
But if I try this from PreUUT, it doesn't know what 'ThisContext' is.  Is there a way to determine the name of the sequence file when we're in the PreUUT sequence?
(3,379 Views)
RunState.ProcessModelClient.Path
PH
(3,373 Views)
It needed 'Caller' just before ProcessModelClient, then it worked.  THanks so much.
RunState.Caller.ProcessModelClient.Path
(3,370 Views)
just a annotation.
I would prefer to use RunState.Root instead RunState.Caller
because Caller is only valid in "MainSequence".
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,351 Views)
