Home
Community
Discussion Forums
Most Active Software Boards
NI TestStand
Topic
NI TestStand
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
display 3 D array in report as waveform
srapp@moog.de
Member
02-27-2007
11:38 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want to store a measured signal waveform into the report with the high and low envelope (according attached picture)
Is this possible
If yes how is it possible?...can anbody give me an example or help
thank you
regards samuel
signal with envelopee.JPG 30 KB
0
Kudos
Message
1
of 3
(3,166 Views)
Reply
Re: display 3 D array in report as waveform
RayFarmer
Trusted Enthusiast
02-28-2007
12:42 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
There is an example in the TestStand folder for adding a picture to the report, this may help.
What format are you using, HTML or XML?
Regards
Ray Farmer
Regards
Ray Farmer
0
Kudos
Message
2
of 3
(3,159 Views)
Reply
srapp@moog.de
Member
Author
02-28-2007
02:26 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thank you ray
Ray, I am using xml report.
There is also an example under Teststand folder\Examples\DisplayArrayInReport where a 1 D array is shown as waveform in the report.
works this method also with 2D or 3D arrays?
regards samuel
0
Kudos
Message
3
of 3
(3,153 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
