NI TestStand
display 3 D array in report as waveform
I want to store a measured signal waveform into the report with the high and low envelope (according attached picture)
Is this possible
If yes how is it possible?...can anbody give me an example or help
thank you
regards samuel
(3,160 Views)
There is an example in the TestStand folder for adding a picture to the report, this may help.
What format are you using, HTML or XML?
Regards
Ray Farmer
Regards
Ray Farmer
(3,153 Views)
Thank you ray
Ray, I am using xml report.
There is also an example under Teststand folder\Examples\DisplayArrayInReport where a 1 D array is shown as waveform in the report.
works this method also with 2D or 3D arrays?
regards samuel
(3,147 Views)
