display one sequence at debug
I have a standard test stand solution like most of yours, a main sequence and many of sub-sequence.
When run single pass in debug mode. the 'single pass' window will show the current sequence or sub-sequence.
My question is I don't care the progress of sub-sequence, I care only the main sequence.
So any way to fix display only the main sequence in that window?
Thank you!
version: TestStand 2014 32bit
(4,252 Views)
Accepted by NemoChen
Hello!
I think disabling tracing may help 🙂
I don't have TestStand in front of my eyes but as far as I remember:
  • select any subsequence (or all of them)
  • on the bottom of the window go to step settings
  • change tracing to: Disable tracing
If you change it your cursor will stay in main sequence.
Let me know if this helped!
mtwar
Think Dataflow - blog.mtapp.tech
(4,230 Views)
As suggested by mtwar, Disable Tracing the Possible option, but if you have a sub sequence which executes for a longer time then it seems like it hanged some where as the user wont be getting any feedback or response still the sub sequence completes its execution.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,214 Views)
Yes, it is excetly what I'm looking for.
thank you!
(4,149 Views)
