dll for NI 6008 in teststand
since 2 days I have been struggling to find a dll or lib which I can use without any problems for controlling NI USB 6008 card. I am not sure if it is possible to control usb from teststand.
All I could find was:
- NIDAQmx.lib file. Which when I tried to use with test stand, most of the function gives following error "PArameter information or user type not recognized by teststand"
- NationalInstruments.DAQmx.dll which is a .net dll. The problem here is if I have to call a function inside a subclass of a class (for example class X has an object of class Y and I am calling x.y.functionInsideY()) whcih is not possible in TestStand (?).
Please post if you know the solution.
Regards
RB
Message 1 of 21
(4,471 Views)
Hi RB,
are you going to use a code module for that or do you want to call the lib direclty in TestStand?
This would not be the normal way to do it, so it would be good if you would explain it a little bit more.
Thanks, RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
Message 2 of 21
(4,452 Views)
I want to call functions inside library. I think its a usual practice in TestStand. I can specify a module in TestStand and then call functions available in it. It can either be a CVI or .NET library/assembly file.
Message 3 of 21
(4,450 Views)
Hi RB,
well, Teststand itself can not communicate with hardware, this is why we have the code modules. If you want to use the DAQmx you could use the dll itselft, but the problem will be that the parameters will not be recognized direclty, so in this case you really have to use code module like CVI. This is the normal procedure we have with drivers.
In CVI you can find  a lot of examples for DAQmx, so I would recommend you, to use that ones and see how it works.
Hope this helps, RMathews
Ramona Lombardo
Message 4 of 21
(4,449 Views)
Hi Mathews,
you are right. The parameters are not recognized by TestStandt. I went through the examples in CVI and the problem is that these examples inlude .h files (NIDAQmx.h..) something that I can not do in TestStand.
-RB
Message 5 of 21
(4,448 Views)
Secondly. it is not easy for me to beleive that "NationalInstruments.DAQmx.dll" is not compatible with TestStand at the time when devices from many companies are compatible with TestStand but NI is not able to do that. I think I am doing something wrong.
I have attached a document to explain the issue. It may help you to help me out.
Thanks for taking time
RB
Message 6 of 21
(4,443 Views)
I dont believe there are many devices, from NI or other companys, that you can directly interface to the device software driver from TestStand. Usually you have go through a wrapper code module.
Regards
Ray Farmer
Message 7 of 21
(4,433 Views)
Accepted by dotNet_to_LabW
Hi RB,
the problem we have here, is that Teststand is not a Programming Language and you can not communicate with the hardware directly. This will not work.
To me it seems that you want to communicate with the driver of the hardware (in this case DAQmx) in Teststand. This is not the way it works.
What you have to do is to write a code module in CVI or .Net, which interfaces with the driver and acquires the data. You would then create a dll or a .NET assembly out of this code and that one you can include in Teststand. You have the driver communication encapsulated in the dll or the assembly and Teststand just calls this "wrapper".
Cheers, RMathews
Ramona Lombardo
Message 8 of 21
(4,432 Views)
Sorry, but by mistake I clicked at "Accept at spoluton" rather that at "replying".
Now you are confusing me Mathews
"........What you have to do is to write a code module in CVI or .Net, which interfaces with the driver and acquires the data. You would then create a dll or a .NET assembly out of this code and that one you can include in Teststand. You have the driver communication encapsulated in the dll or the assembly and Teststand just calls this "wrapper".........."
So you mean, although a dll is already available from NI (as NationalInstruemnt.DAQmx.dll) and I should make one more dll to call functions inside the NI dll file in order to communicate with hardware?
I have Keithley, Agilent devices which supplies .dll that I can connect directly in TestStand.
Message 9 of 21
(4,428 Views)
Hi Farmer,
but what is a wrapper code module?
Ultimately you write some code to communicate with hardware, wrap it in dll and make it available it to TestStand. So if a company is already supplying "wrapped code module" then why to abstract it once again in own wrapper.
By the way, I have 7 devices with me from different companies and except NIDAQmx, I did not write extra code (wrapper) for testStand. I used simply dll supplied with them.
Regards
RB
Message 10 of 21
(4,426 Views)
