NI TestStand
error code -2147467259
After closing a (teststand) custom user interface and then attempting to restart the application the call to open the TS.Engine reference fails with the following error -2147467259 Any suggestions as to why ?
(3,528 Views)
That error code is a Windows OLE error: EFAIL. Unfortunately, the Windows description is "Unspecified error". You might check the process view of the task manager to make sure your application is not hanging on exit. Other than that, my only suggestion would be to utilize your source control system to "binary search" for the change that introduced the failure.
(3,528 Views)
