NI TestStand
networked string resource files
I've created some custom string resource files for user interface messages such as message popups. I've located them in the Components\User\Language\English directory of each computer running TestStand. Instead, I would like to have a single copy on a networked drive so that I only have to update a single location when the strings change. Is there any way to have TestStand automatically load non-local string resource files and have the ResStr function work.
(3,050 Views)
As you have determined, ResStr will work for the files you add to Components\User\Language\ or Components\NI\Language\ (as documented starting on page 3-6 of the TS user manual). However, at the moment there is no way to redirect TestStand to look in a directory located on a server.
NI has documented this suggestion and will consider it for future releases of TestStand.
(3,050 Views)
