02-14-2006 08:58 AM
02-14-2006 03:22 PM
Jason
I have a couple of questions to help debug this issue.
1. Does the error with 'GetXML' occur with simple sequence files ie try the computer mother board examples which ships with TestStand
2. When you get the error with 'GetXML' do you approximately know how many steps have executed?
3. Are you using the default process model or a modified version ( specifically are there any changes with regards to report generation)?
Thank you
Anand Jain
National Instruments.
02-15-2006 06:57 AM
09-25-2007 12:35 PM
Hi Jmurray,
I have the exact problem. Did you solve it? Do you know what was causing it. I'm using TestStand 3.5 and don't know how I get this message with 3.1 in it.
Rafi
09-25-2007 12:39 PM
Hi Anand,
Is there an explanation why API 3.1 is indicated when I'm using the 3.5 version. I might had a 3.1 version installed on this pc before I installed the 3.5 (not sure about it...). In any case, there is no TestSTand 3.1 directory but just \TestStand\
I don't get this error with other sequences but just with this one.j
Regards
Rafi
09-25-2007 12:59 PM
09-25-2007 02:05 PM
09-25-2007 02:55 PM
Hi Anand,
I was able to solve the problem, and it was due to a wrong parameter sends to a CVI module.
I'm still confused as the connection to the step where the error shows up (Report callback) and why is the indication to TestStand 3.1
Any suggestions?
Do you think I should "clean" the register from any trace of TestStand 3.1?
Regards
Rafi
09-25-2007 03:10 PM
09-25-2007 03:16 PM
