NI TestStand
exclude main from report only report for subsequences
Hello all,
I have made a sequence(main) which calls a subsequence.
The subsequence is called with the option " Use New Execution".
Now I get 2 reports, 1 from the main and one from the sub.
If I run this test I only want to record the report from the subsequence and not the main.
How can I disable the report generator for the main?
Maybe in the 'ReportOptions' call dont know which parameter and maybe I mess it up when making the wrong settings?
Bart
(2,998 Views)
Thanks for your posting here.
Can I look at your code?
Hossein
(2,979 Views)
