NI TestStand
format string
I write the error message from Teststand to text file. How do I format the error message so that ascii character do not show in the text file? For example the error message is:
"Resource not initialized!
Resource Name: 'Temp#1'
Source File: 'List.c'
Source Line: 2745
Function Name: 'List_Write'
Error Code: 0xFFFFFFFE
When written to text file it displays as shown in the attached image.
Thanks.
(3,492 Views)
What command are you using to write the file?  The problem isn't with the format in TestStand it's how you are pushing it to the file.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,467 Views)
