export TS 3.5 limits
I have TS 3.5 and LVIEW 8.1,  In Main Sequence, I have about 20 TestSteps multiple numeric limits. when I try export the limits by clicking on the "limits" button. only three lines are shown on the right panel
step.measurement[?].comp
step.measurement[?].limits.low
step.measurement[?].limits.high
when I click export the pop up window respond with 0 value exported.
Q. should I replace ? with 0, 1,2,3....?
Q. should I add index for the step ?  ex: step[0].measurement[0].limits.low..... step[1].measurement[0].limits.low....
I have twenty steps to fill out,  is this correct?
Message 1 of 12
(4,936 Views)
Not sure if you have twenty steps which are multiple numeric limits steptype or you have a step which is a multiple numeric limit steptype which has twenty limits!
You have to replace the ? with the required index value i.e 0 or 1 or 2......19.
So that 20 (x 3) items are exported you have to define all twenty of the step.measurement[0].comp .... step.measurement[19].comp. Likewise for the limits.low and limits.high
so to answer the Question
Q. should I replace ? with 0, 1,2,3....?        Yes.
Q. should I add index for the step ?  ex: step[0].measurement[0].limits.low..... step[1].measurement[0].limits.low....   No   When you export it will scan the whole sequence looking for occurances of step.measurement[0].limits.low etc. step[0].measurement[0]....doesn't exist.
Hope this answers your questions
regards
ray farmer
Regards
Ray Farmer
Message 2 of 12
(4,926 Views)
Hi Ray,
I have 20 teststeps
  there are steps with 3 readings in each test step
   and there are steps with 6 readings in each test step
 the readings are place in the TestStand Measurement array ( in LabVIEW) VIs
 and in TestStand when I set the limits  (low, high)  data source  : NumericArray,
( in the prototype pop up window, I have to choose NumericArray to see the returned results)
together I should see about   = (20 steps  x 3 or 6 values per step x 1 low limit) + (20 steps x 6 or 3 values per step x 1 high limit)
Also after click 'export', I see the pop up window displays 0 value export.,  this window may give a clue of something wrong.
Message 3 of 12
(4,914 Views)
Hi trout00,
Does your export dialog look something like the attached picture.
regards
Ray Farmer
Message Edited by Ray Farmer on 01-12-2007 09:36 PM
Regards
Ray Farmer
Message 4 of 12
(4,910 Views)
I have attached the screen shot of the export screen, I don't have station globals on the left panel In the limits window, the limits data source array expression  : step.NumericArray In the load prototype window, I have set   Measurements: 1D Array (DBL) - out - Step.NumericArray Thank you for helping
Message Edited by trout00 on 01-15-2007 02:10 PM
Message 5 of 12
(4,888 Views)
Hi trout00,
I shouldn't worry about the StationGlobals, it just means you haven't any StationGlobals defined, likewise on my JPG example, I didn't have any Locals defined in the Sequence. Similarly, if you had defined some FileGlobals in your sequence file, then there would be a FileGlobals entry added to the list.
The window on the left, is all the Properties that are available for you to export / import.
You will have to replace the ? for the index value you wish to export.
Regards
Ray Farmer
Regards
Ray Farmer
Message 6 of 12
(4,858 Views)
Ray,
Is this a manual process?
so for my step 1, I have six measurements [0..5], I should start with
Step.Result.Measurement[0].Comp
Step.Result.Measurement[0].Limits.High
Step.Result.Measurement[0].Limits.Low
Step.Result.Measurement[1].Comp
Step.Result.Measurement[1].Limits.High
Step.Result.Measurement[1].Limits.Low
Step.Result.Measurement[5].Comp
Step.Result.Measurement[5].Limits.High
Step.Result.Measurement[5].Limits.Low
this one test step  (test step number 1)
for the second test step, I have three measurements [0,1,2] I should start with
Step.Result.Measurement[6].Comp
Step.Result.Measurement[6].Limits.High
Step.Result.Measurement[6].Limits.Low
Step.Result.Measurement[7].Comp
Step.Result.Measurement[7].Limits.High
Step.Result.Measurement[7].Limits.Low
Step.Result.Measurement[8].Comp
Step.Result.Measurement[8].Limits.High
Step.Result.Measurement[8].Limits.Low
this is test step number 2 with three measurements,
and continue with  teststep number 3, 4,,,,,,,,until 20 or whatever last step?
it seems this is very prone for error, it relies completely on the human, with no error checking.
Do I miss something ?
Anyway, please let me know if this is the method? if I have to peck on the keyboard, then I will.
Message 7 of 12
(4,855 Views)
Hi trout00,
Yes it very manual,
So for step 1, this is correct
But for Step 2
It should be
Step.Result.Measurement[2].Comp
Step.Result.Measurement[2].Limits.High
Step.Result.Measurement[2].Limits.Low
for Step 3 these will also start from index 0.  Hope you get the picture.
Unless of course you have something werid in your step definition for the Limits, each Step starts from index 0
In the Export / Import tool, you are not actual specifying the actual steps, you are specify the properties of a Step to export.
So if you had 20 Step but the maximum number of limits in any of the 20 steps is 6, then in your Export Tool you would only need
Hope this make sense.
Yes it is very prone for error, especially if you are dealing with a lot of properties.
Regards
Ray Farmer
Regards
Ray Farmer
Message 8 of 12
(4,851 Views)
Ray
so when I import back in from a text file (or excel) , how does the TestSTAnd knows which limits match with the steps.
regards
Message 9 of 12
(4,848 Views)
Hi trout00,
Its uses the Step Name to match which limits go where they should.
I have attached an example. (TS3.5), you should beable to match the limit file with the sequence steps.
In the Export/Import  Tool I have the following properties
Regards
Ray Farmer
Regards
Ray Farmer
Message 10 of 12
(4,840 Views)
