NI TestStand
failed loop appears to pass
I have a pass/fail test loop sequence. Soemtimes, two of the sequence steps fail, yet the sequence as a whole passes. Is that a bug in TestStand? I am using TestStand 3.0. Is there a chance that this is a bug which was fixed in a later TestStand version?
(2,961 Views)
Hi AlanJ
Can you post an example that other members or I can take a look on it
Greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(2,951 Views)
In the step properties under the run tab is an options called Step Failure Causes Sequence Failure. Make sure this is enabled.
Regards
Ray Farmer
Regards
Ray Farmer
(2,947 Views)
