Hi all - I am using the flow step types to load values into a local array in the set up routine. The problem I have is that the generated report contains every iteration of my code.
Open up the step properties window. Click on the Run Options tab. Unselect the Record Results checkbox near the bottom of the tab window. You can do this on any step that you do not want recorded in the report.
