NI TestStand
flow steps
Hi all - I am using the flow step types in TS 3.1 to load values into a local array in the set up routine. The problem I have is that the generated report contains every iteration of this code.
The question is then - can the flow code ( or more generally code written in the setup tab) be inhibited from appearing in the UUT Report.
thanks dht
(2,963 Views)
Hi dht,
You cant switch off the reporting of an individual group such as the Setup. You will have to switch off the reporting for each step in the Run Options tab of the properties of the step. You can switch off the reporting for the whole sequence in the properties of the sequence.
Regards
Ray Farmer
Regards
Ray Farmer
(2,961 Views)
hi Ray , thanks for the clarification.
dht
(2,956 Views)
