hide sequence from being called by external test sequences
In TestStand, is there any way to hide a sequence so that it can't be called by a test sequence in another sequence file?
Melissa
(2,960 Views)
No.
You could do something similar thats done in the process model sequence file, SequentialModel.seq. That is to check if its been run from valid sequence or sequence file. The SequentialModel.seq entry points, Test UUTs and Single Pass, do a check to see if they have been run from a client file. They terminate the execution if it hasn't
Regards
Ray Farmer
Regards
Ray Farmer
(2,951 Views)
