NI TestStand
how to Get Step.Result.ReportText in operator interface
Hello all:
I met a problem: I want to get report text of every step in operator interface. I use TS_StepGetProperty method but it seems there is not property ID indicate report text. Can you help me, Thanks advance!
regards
Cheng Zhang
(3,107 Views)
ReportText is a custom step property, not a static step property. Thus there is not a "hard coded" function to access it. Here is some code that should work:
// error checking omitted
void foo(CAObjHandle step)
char * reportText = NULL;
VBOOL exists;
TS_PropertyExists(step, NULL, "Step.Result.ReportText", 0, &exists);
if (exists)
TS_PropertyGetValString(step, NULL, "Result.ReportText", 0, &reportText);
// use reportText here
CA_FreeMemory(reportText);
(3,107 Views)
