NI TestStand
how to convert ini files from TS3.5 to TS4.1
I'm going to start working with TS4.1 in my next project.   I would like to use some of the ini files I've used before on other project using TS3.5  (stationGlobals.ini, users.ini  etc..).
What is the best way to convert those file for TS4.1?
Rafi
(2,945 Views)
I've just started upgrading from 3.0 to 4.1.  I believe you can just copy these ini files into the new Cfg folder for TS 4.1.
Note that the files you mentioned as well as your frontend callback and process model changes are now stored in a new directory structure that allows TestStand 4.1 to be Vista compliant. There are shortcuts in the TestStand 4.1 folder that will point to the relocated folders for your Cfg and User files...
What is New for TestStand 4.1 - Directory Relocation
(2,937 Views)
