NI TestStand
how to define sequence parameter by default as 'Use Default'
Hello
Is there a way to define sequence parameters so, that in every instance of this sequence the default checkmark of the parameters is set to 'Use Default' ?
If this is possible is it only for all parameters of an sequence, or for can it be changed for any of the parameters individualy.
Olli
(3,007 Views)
Dear Olli
I don't think there's a way of automatically checking the "Default" option for several sequence parameters. You will have to do it for each item individually.
Best regards
Philipp Roessler
(2,959 Views)
