NI TestStand
set global variable with c#
HI,
i am trying to write a c# programm that set a global variable. The problem is that it doesn't walk everytime. sometime it walks, sometime not.I can always read the current value, but it is not always possible to change it.
 i don't know what i'm doing wrong. hier ist the Code:
IEngine
IEngineObj=null;
PropertyObject PObj=null;
IEngineObj =
new Engine();
PObj=IEngineObj.Globals;
if ( PObj.GetValBoolean("Config.UseConfig", PropertyOptions.PropOption_NoOptions))
PObj.SetValBoolean("Config.UseConfig", 0, false);
 else
PObj.SetValBoolean(
"Config.UseConfig", 0, true);
PObj =
null;
IEngineObj =
null;
Teststand 3.5
Visual Studio 2005
(3,848 Views)
You dont trap for any error conditions!
Does "Config.UseConfig" exist all the time? If not check for its existence and if it doesn't exist use
PObj.SetValBoolean("Config.UseConfig", 1, true); with the options set to 1.
Regards
Ray Farmer
Regards
Ray Farmer
(3,829 Views)
HI Ray,
"Config.UseConfig" always exist. with the option set to 1, the problem can't be solved. i tryed it without success.
Noubissi
Teststand 3.5
Visual Studio 2005
(3,799 Views)
