Home
Community
Discussion Forums
Most Active Software Boards
NI TestStand
Topic
NI TestStand
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
how to display runtime error couse
mitulatbati
Active Participant
04-26-2007
07:12 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi all,
I use TS3.0. At calling a .vi, the system goes to runtime error state. A StationCallback.seq is called, and the error is handled there. How can I display the reason of the error?
regards
mitulatbati
0
Kudos
Message
1
of 2
(3,039 Views)
Reply
Re: how to display runtime error couse
kevmi2ca
Member
04-26-2007
04:01 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Try this:
>Configure
> Station Options
>On Run Time Error = Show Dialog
This should display the error. Also ensure your errors are passed from vi to TS using connector pane.
0
Kudos
Message
2
of 2
(3,032 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
